colbyc
- 690
- 55
- Oct 10, 2007
Arkansas
This is the Build Thread for 97 GSX Project "Money Pit". Reply below.
, throttle body shaft seals leaking, a bunch of small wiring issues, most disappointingly a spun rod bearing, and a tune that explained the spun rod bearing.I have another one of the 3D printed mounts ready to go if it would interest youI've spent a good bit of time cleaning up and removing wiring along the way. I started out with doing some research on dsm fueltech conversions and came across @jdxnc thread which helped a ton and made it less daunting. So I really liked the idea of using the factory gauge cluster bezel as a backing for the fueltech screen and nano wideband. I modeled up a mount for it off his design.
At this point I've got the ecu/wideband mounted and harnesses routed but unterminated. I've still got to make the backing for the gauge bezel.
Just a small update. I've put close to 300 miles on the car so far, which doesn't seem like much, but it's 280 more than the amount I've been able to since I've owned it. Everything has been working well. I've had very little blow by doing several WOT pulls tuning. No dip stick popping out, catch can has barely had anything in it. Not sure if it's just everything is healthy, or the valve cover and crank case ventilation doing their job. Either way, it's pretty awesome coming from previous DSM's where I fought this alot.
Here's a small "low boost", low timing 2nd gear pull. Sorry for the bad quality in advance.
That thing rips, man. The FP Black seems like it hits hard. I love the FuelTech too.
This is rad!
Very similar to my feelings after switching to FuelTech. I was fighting electrical issues left and right beforehand, and a sealed catch can setup made a big difference with my blow-by issues too.
