zero knock help
bigtim-x
37
Jan 7, 2004
hemet, California
I have a pocketlogger. I have had it for about three months. I have not seen any knock change the count/sum always stays at zero. I have a AFC, my timming is being pulled when running to lean. So I know my knock sensor is working. But pocketlogger still shows no knock what so ever. Has anyone experienced this problem? Talked to the tech at pocketlogger. He was a smart A He said I thought know knock was a good thing. But I know I should be seeing some kind of knock. See my profile for mods. only change is convert back to 1g mas waitng for 680 inj. thanks.
I had something similar to this happen to me. Logger would show no knock yet timing would get pulled like crazy sometimes to 0!! After changing a lot of things, I swapped the ecu and it started showing knock big time! You may want to try this.
I Fixed My Knock Problem. I Had My Orignial Ecu In My Car It Burn Up. I Replaced It With An Ecu From The Junk Yard. The Ecu Was Realy Nice It Had A Disconnecting Chip Board. The Board Was Really Clean. Looked Like A Brand New Board. New Compasitors And Everything. The Replacement Ecu Was My Problem. For Some Reason The Chip Would Not Allow Me To Read Knock On My Palm. I Have Know Idea Why. But I Put In A Replacement Chip(the Dsm Chip By Keydiver). Know I Am Able To Read Knock On My Palm. Look For This Chip If You Are Having Know Knock Read It Maybe Your Problem As Well.
