knock knock! who's there?
autronicDSM
925
6
Dec 4, 2002
Kalamazoo, Michigan
So I went little too timing-happy on my car. Looks like I have to buy SafeGuard after all to tune my stand alone. How bad did it knock to cause this? I never heard a single ping.
It runs like champ though 175psi compression all across. So I added 2 degrees acros the board and this happens in less then 100 miles of cruising, not even WOT.
Oh and by the way, spark plugs look great. It's this dark coff-ish color. There's no signs of detonation. I'm stumped :confused:
No, motor didn't blow. I took it out to remove balance shafts because belt snapped and took out CAS. I've noticed all 4 pistons are chipped on the intake side and are burned up. If you noticed directly in front of where intake ports are you can see missing chunks but as you move out piston is smooth. Bummer is I don't have cash to get new forged pistons. I think I'll invest into J&S Safeguard first.
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
  • For sale 2g 2GA Eclipse Fog Lights & Brackets
    2GA Eclipse Fog Lights & Brackets $70 + shipping and PayPal feesYou must be registered to see...
