zero for 2- motors
ktmryan53
51
3
Apr 4, 2005
cleveland, Ohio
ok so i blew up my first motor with 103 k on it. i figured it was crank walk but now im not positive. it blew the balance shaft out of the rear of the block(pics look pretty cool) and blew 2 holes in the front of the block which one of the pieces cut the front radiator hose(small one next to oil pump). i pick up another 7 bolt with 72k with great compression. i figure that this motor will be great for me. it lasted 73 miles until it blew up in the exact same place but this one i knew what the sound i heard was so i got the motor off quicker. it only blew the rear balance shaft area of the block off but the balance shaft stayed in the motor. both times happened in the exact same spot on the freeway, and both were downshifting from 5th to 4th gear. anyone know what might be the common theme here?
sounds like the common theme there is to remove the balance shafts next time you put a motor in! :thumb:
anyways we need some more info to help you out man. it could be alot of things...
i agree that is the theme, but im not sure on that the original problem was. what other type of info do you need?
yeah great idea, spend a couple grand on a car that is only worth a couple grand. these are dime a dozen cars. i dont believe it was the balance shaft anymore. i am leaning towards the car running lean then detonating until catastrophy.
