question for those who pull their motors frequently
spaceball
79
Jan 19, 2004
wakefield, Massachusetts
is it doable to sneak the motor out without the tranny? does removing the balancer and pulleys gain enough clearence to slide the clutch off the input shaft?
Its do-able, but harder....
I know there are topics on how people got it out without the tranny. Id search for that.
Why not just take everything? Its not that much more work.
i am lazy. i dont want to deal with the 3 driveshafts floping around when i push the car outside . now i know it is possible it is what i will do. maybe i'll do a write up if one does not allready exist.
I've been part of an engine pull where we didn't even remove the crank pulley. I was not really in favor of that decision. The crank pulley wedged against the frame rail and the only way to clear it was by whacking it with a mini-sledge, so in the end it was destroyed. If you take off the crank pulley, it should come out without too much fuss. I think it's easier just to pull it as a unit, though.
I didnt take off my crank pulley and the engine came out fine......
But ya...Do a search. Its been said how to do.
Yes, I pulled it without taking the tranny out. Little to much of a pain in the ass to do it that way. When the engine was ready to go back in I pulled the tranny and mounted it to the engine and dropped the whole thing in as one. This was a MUCH better way of doing it. From then on, it was in\out as one unit.
its easier purely from being able to access the tranny bolts,
unless you have a lift at your disposal,
and then theres always the torn/frayed broken stuff that goes when something goes wrong
ok so i have everything unbolted. i see why this is not common practice. as far as i can tell it is not even possible. i have the pulley out, crank bolt out and the accessories out. there is not even close to enough clearance. i need about 2 inches more to get the clutch outta the bell. it may be because of my clutch flywheel combo. now i have to drop the tranny. damn.
jack the tranny up, while the motor is moving out also. just did this with a buddy of mine. But the hard part was puttin it back in. Take it out as a complete assembly. More time will be spent tryin to pull it n put it back in, with the tranny still in the car
