Yanking the Engine and Tranny
wings9191
212
Nov 23, 2003
Lima, Ohio
Someone who has pulled an engine and tranny from a 91ish eclipse, Does the whole thing come out the top or the bottom ?
Yes i have pulled engine and trannies before, but never on a 91 eclipse.
Everything I looked at only talks about 1 or the other coming out and not pulling both. Looks like it drops out the bottom, Is this true ? Or do I have to take them out 1 at a time ?
Thanks guys
Jay :talon:
hook up your hoist so the engine side is a little higher than the tranny side,
start jacking, the angle should give enough room to clear the tranny side of the bay. some tugger and shoving may be necessary.
i always take the whole out the top.
and ABS car might be harder, with the abs box in the way
Ok cool so just do the angle thing ?
If you say so, I will be doing it tomorrow.
Thanks for the help.
Jay :talon:
P.S. I don't mean to sound like I'm questioning you, Just from looking at it it looks like it would be easier out the bottom. But I do understand what you are saying and will be singing your praises in a day or 2.
Thanks again
drive shaft nut? or axle nut.
vfaq.com
click on drivetrain
and axle replacement, shows the size for axle nut.
i always take mine out the top, unless you have a put, or a hydrolic lift, you wont be comming out the bottom.
the passenger side tranny mount comes off by 4 bolts inside the fender well, this is amust. cant just pull the bolt from the center.
