Wrinkle valve cover write up
Rudie4
43
4
Apr 25, 2011
Riverside, California
So I just had surgery for a new ACL so I have a lot of time on my hands and I thought I'd do some fabrication to my extra valve cover. I've always been interested in those wrinkle look so I did a write up if anyone is interested.
-So to start off I took my backup valve cover the red lettering was already starting to come off and the grey wasn't looking so good either
http://s1287.photobucket.com/user/05Gixxer/media/null_zpsc8debc5e.jpg.html]
[/URL]
-I filled a bucket with some degreaser and water and let it sit there for 10 min
-Dried it off with a towel and used tape to cover up all the holes
-After a heavy first coat
-Left outside in the sun for 5min before applying a heavy second coat, still no wrinkle
-Waiting 5 more min and you can see the wrinkles starting to form, this picture is before the third and final heavy coat
-Gave the valve cover 24 hours of sitting under the California sun and you can really see the texture
-Used a Dremel and razor blade to expose the lettering and arrows
-Purchased a small paint brush from a hobby store and red engine paint in a can for the lettering. Just sprayed some paint in an old cup and a steady hand. After drying this was the final result
-A before and after
You should sand it with 600 grit or a scotch brite pad before painting, otherwise that will flake off over time.
Here's mine; same stuff. After you drive it a couple times, it turns hard as nails.
I was going to suggest the same as colt, your pics don't show any kind of prep work. I hope its just miising from the details. Or you will be redoing is very soon.
thanks everyone and yes i did prep it with some sandpaper dont know what happened to the pic but i only used 1k grit paper. Havnt installed yet
Damn, that sure beats sending it away to get done. Looks amazing. Well done and thanks for the how to.
