Cam Position Sensor Write up
Tison28s
32
Jan 8, 2009
sterling, Virginia
Does anyone here have a write up on how to install a cam position sensor/crank angle sensor on a 92 eclipse gsx?
The CAS can only go into the cam two ways, correctly and 180 degrees off.
Make sure that you are really grounding the pin for the timing adjust connector and not the plastic guard and that you have disconnected any datalogger (grounding pin 10 on the DLC at the same time will set the BISS adjustment mode not timing adjust mode)
Steve
and here is how to set timing Engine Timing
