worn cylinders need new pistons?
jdombrow
130
Nov 13, 2008
Escanaba, Michigan
wondering, planning on doing a 2.3 6 bolt build with wiseco pistons. planning on having bored out 020, if i rebuild next year and pistons wore away cylinder walls, do i need to get rebored and new pistons. or can i get a bored and bigger rings.
id check the wear but really if u have no scared cylenders you should be able to get a way with a hone and the samw size rings if a machine shop is doing the work they can tell you weather to hone or bore. i ringed my motor last year it had 170,000 on it and i hone it mu self and put standard rings on the same pistons it still runs top noch with 180psi on all 4 cylenders and uses no oil.
There is no way for us to know. You have to check the piston to wall clearance and compare it to the specs of the pistons.
yes but can you buy bigger rings? to take up te exctra space if it has to be bored instead of buying new pistons
This whole cars thing is new to you, isn't it?
Yes, new bore sizes need new pistons. Rings don't "take up the space".
Read much, much more before asking similar questions.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
