Working out the details- Head Build and more.
fourgsixthree33
1,244
46
Oct 25, 2010
Athens, Pennsylvania
I think I got a good bit of my parts list for my upcoming build. Just with this stuff, I am looking at almost $800. I didn't intend on spending that much but if I am going to do things right, then that's what it's going to consist. It would be dumb to install a new head with aftermarket cams with out getting all my timing belts, tensioners, pulleys, etc. If I get all this done and the belt snaps a week later or the tensioner takes a shit, I am not going to be very happy.
After taking a look at the list and parts I am going to get, it made me not want to stop. I will also be getting a new water pump, injectors, oil pan gasket, passenger front axle, torque convertor seal, as well as some other things. I have never been able to deal with not being able to drive a DSM when it is down, so I think it is about time I suck it up and build. Sure, I could have all this done and no time. But the couple of weeks of down time would be for nothing if I don't give the car some go fast parts and have the same amount of power I did before all this work. It's time to make my work count.
I would like some more idea's on what to get and do while the engine is dissembled. My oil pan gasket is leaking. So I will put on a new gasket, my tranny is messing up from a bad torque convertor seal, and the passenger front axle is clickity-clicking. There are several things like this that I will be taking care of all in one shot.
Heres the list so far:
1G 7 Bolt Head- $125
Engine Gasket Kit- $128.94 http://www.summitracing.com/parts/SLP-260-1704/?rtype=10
Webs 546/547 Cams- $155 (bought from a friend. Good deal.) Web Cam Inc. - Performance and Racing Camshafts
ARP Head Studs- $65 used. Low Miles, torqued once.
Gates OEM Timing Belt Kit- Black Belt- $145.92 Comes with all tensioners. http://www.thedsmgraveyard.com/Produ...CK167&CartID=1
APR Lubricant- $2 ARP 100-9908 - ARP Ultra Torque Assembly Lubricants - Overview - SummitRacing.com
HKS Pink Oil Filter- $25 http://www.streettunedmotorsports.co...oil_filter.htm
Royal Purple 20W-50 Motor Oil- $50
Torque Convertor Seal- $6.51 RockAuto.com
Passenger Front Axle- $53.79 RockAuto.com
Oil Pan Gasket- $4.18 RockAuto.com
Transmission Filter- $18.43 RockAuto.com
Right Rear Brake Caliper- Warrantee from Carquest
Walbro 190 Fuel Fump- $90 Ebay.com
