Engine Build Part 2: 4G64 Shortblock Details
kwbunn
54
Apr 20, 2007
Virginia Beach, Virginia
The block is at Jackson Auto Machine now. I'm going to get the block assembled except for the front cover and oil pump.
NEW PARTS:
- Wiseco 9:1 coated pistons
- Eagle H-beam connecting rods
- ACL rod and main bearings
- Coated shaft bearings
- ARP main studs
- New piston oilers and gaskets
- New freeze plugs and galley plug
- New head to block dowels
- New 7-bolt front cover and oil pump kit
MACHINING:
- Cylinders bored .020" over
- Torque plate honed
- Parallel decked
- Line bore check
- Clean and magnaflux crankshaft
- Polish and mike crankshaft
- Complete rotating assembly precision balanced
- Block machined for piston oilers
- Clean, mic, polish both balance shafts
- Install 5 deck plugs to match 4G64 block with 4G63 head
I decided to get the block assembled because I wanted professionals to do it. Jackson has the correct machinery and tools necessary to do precision work, and I wanted the balanced assembly *in* the block when I received it. Jackson and i agreed on keeping the balance shafts in the motor - they're there for a reason. One of the cool things they're doing is machining the block for the oil squirters. When the block comes back I'll take pictures and post them.
