won't turn over
avaien
242
24
Nov 30, 2003
Cincinnati, Ohio
I have a 99 gst. I was cruising at about 60 and my car died. It rolled to a stop and everything was dead. I looked at the fuses and the ignition switch had blown so I swapped it for the power windows. I got my power back but when I tried to start the car it wouldn't turn over. It will crank but not start. Yesterday I installed a walbro 255hp fuel pump and an aeromotive fpr. I set the fuel preasure at idle to about 45. Is the fuel pump dead? Is the engine clogged with fuel? Motor blown? what should I look for
When you turn the key to "ON" can you hear the fuel pump turn on. I have the same fuel pump and you can hear it when it kicks on. It sounds like a low hum. You said that it was turning over, do you have spark? Check your spark and see if you can hear your fuel pump first. When it is cranking can you hear it firing? Does it sound like it is at least trying to start?
if you cant hear it running from outside the car take the gas cap off and put ## ear up to it and have a friend turn the key on it u should hear it running.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
