wont stay started
Boost leak check.
When was the last time you changed the fuel filter?
What kind of plugs, when were they last replaced?
Condition of your wire?
well i know it needs a major tune up i jus bought the car a cople months ago so im still finding out the problems but i put plugs about 2 or 3 months ago i dont know how long the car was sitting before i got it but im gonna relace the wires,plugs,fuel filter,a good oil change i bosch double platinums i was told to change to NGK plugs
Did you do the tune-up items you previously talked about? If not, you need to do those things and go from there. Yes, you should use the NGK's and not Bosch Double-junk.:notgood: You also should hook up the BOV again instead of venting it and see how it runs then.
i have the same prob. the guy i got the car form says its the coolent temp sensor, check the DTC (engine codes)
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
