1G wont start after new timing belt install
dszx13
Jan 13, 2010
minden, Louisiana
installed new timing belt and balance shaft belt an it wont crank. made sure the #1 piston was at tdc, all timing is lined up right. gettin fuel an spark in all wires. wandering if anyone can help me out. first attempt to do this
its 6 times for all the marks to line back up if i remember. and what cylinder did u use for #1 the one closest to the timing belt?
number 1 piston being closest to the timing belt. not sure if its right. tried it again today an it still wont crank. when i checked the timing all was good but the oil sprocket it was off so i redone the belt. pulled the valve cover an everything looked good i jus dont kno why it wont run. LOL
Well go backwards what was wrong if anything before the timing belt, job. I had nicked my valves everything was dead on, but nicked them just enough so i had no compression. This time everything is redone, and it runs. If all was good before the tb job then something went wrong. Compression test will resolve your problem, for starters.
I would say you most likley bent your valves. Doing 20 or 100 your motor doesn't care. 2 things can't be in the same place at the same time at any speed.
Compression test.
what book did u use ? u do know that 90 91 have different timing marks than a 92 94 sure u dident use the wrong diagram ?
i used the chiltons book. i got the marks right. 100 percent positive. put the belt on/off 8 times. jus hoping i was wrong. when i try to crank it..it sounds like it wants to but it aint. if i can i'll get a video
definatly bent valves the first 1 ever did i bent valves just cranking it. second time it happened when i was backing out the garage basically coasting bent the valves also. just save urself the hassle of trying to figure it out and pull the head almost positive ull find bent valves
can u spin it over by hand without alot of resistance?
How fast you were going is not relevant. If the engine was spinning and the belt broke then you have bent valves. As for the not cranking issue, if you can turn it by hand the starter should also be able to turn it regardless of whether your bent valves allow it to actually run. If it won't crank then I'd suspect the starter as either bad or not being triggered. Did you pull or disconnect the starter for any reason? Try shorting the battery straight to the starter and see if it cranks.
You would not be able to tell if you have bent valve by taking off the valve pan cover. You have to do a compression test or pull the head. If the belt broke it is almost a 100 percent guarantee that you have valve damage.
When trying to start the car does it seem to crank faster than it used to?
With compression loss the engine will crank faster because there is little to no compression building on the compression stroke.
Edit: I missed where OP said not cranking I thought he was meaning it would turn over but not start.
You should look for about 150psi on each cylinder if i remember right. But the Chilton's manual will tell you...
