won't rev once boosted
edmcz28
May 29, 2010
Bellmawr, New Jersey
car seems to do fine in first with low boost but when in other gears once its fully boosted the rpms go up very slow starting at around 4000. its not fuel cutting or anything like it will keep accelerating at that point just really slowly. what could this be? and its all stock and running off of wastegate pressure
i did a boost leak test awhile ago and didn't find any, but i will do it again. now is there anything else it could be if no boost leaks?
If it was a boost leak it would more than likely sputter at some point which you said it didnt so thats ruled out.
welcome to the club i have a VERY SIMILAR PROBLEM
PEOPLE TEL ME COIL PACK
SPACK PLUGS AND WIRES
O2
FUEL PUMP AND WIRES
I CHANGED 3 ECUS AND NO DIFFRENCE IF YOU FOUND WHAT IT IS LEAT ME KNOW
GOOD LUCK
