Help! [Engine won't rev]
lil flip 6
32
May 10, 2006
Compton, California
When I step on the gas my car barely goes then it stops then it will go again but it doesn't get over like 5 miles per hour. Does any one know what could be wrong with it? I got the engine only a couple months ago.
hmmm, you have not said what you have tested and not tested, I would start with the basic tests first, definately do a boost leak test and check your timing marks and timing position. then if you dont find anything wrong there, check your fuel pressure, engine compression.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
