Engine won't rev past ~ 4k
daveyfx
236
6
Dec 21, 2004
Orlando, Florida
Hey all,
This problem just hit me out of nowhere. I fired up my 99 GST to go home from work and in first gear it felt like I hit fuel cut just before 4k RPMs. I would say that at around 3,800 it just refused to go any higher and felt like it hit a brick wall.
I proceeded to circle around my apartment complex a few times and sure as anything it experienced this fuel cut-like problem consistently and in any gear that I was in.
Any ideas?
I am gonna go out on a limb here. Since you said it is out of nowhere. But did you happen to install any sort of a stutterbox or rev limiter of any sort? Or if you have one installed maybe the clutch switch it is wired to is stuck in.
I've got no stutterbox system. All my mods are in my profile :)
This is "on boost" I guess. Half-throttle is enough to cause the problem at least.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
