Wiring Factory Ignitor Into Ignition Bypass Plug
My AEM C2DI decided it didn't want to work anymore. The C2DI was wired in without the factory Ignitor causing the car not to run when using the bypass plug. In order to fix this I decided to wire the Ignitor into the bypass plug.
It was pretty simple if you know how to solder and crimp wires and what not.
The C2DI uses a 12 PIN Deutsch connector with the following pin outs:
  1. Ign1 Input - White
  2. Ign2 Input - Green
  3. IgnOn +12v - Red
  4. Ign3 Input - Yellow
  5. Ign4 Input - Violet
  6. IgnOn +12v - Red
  7. + Coil 2 & 4 - Pink
  8. - Coil 4 - Gray
  9. - Coil 3 - Blue
  10. + Coil 1 & 3 - Tan
  11. - Coil 2 - Orange
  12. - Coil 1 - Brown
The Mitsubishi Ignitor (Power transistor) uses the following pin outs:
  1. OC2 - Blue/Black
  2. IB2 - Tan/Red
  3. GND - Black
  4. TACH - White
  5. Empty
  6. VB - Black/White
  7. IB1 - Black/Blue
  8. OC1 - Black/White
And now for the fun part... make the following connections to the C2DI connector:
  1. IB1 - Black/Blue
  2. IB2 - Tan/Red
  3. VB - Black/White
  4. Empty
  5. GND - Black
  6. Connect to PINs 7 & 10
  7. + 12V from PIN 6
  8. Empty
  9. Empty
  10. + 12V from PIN 6
  11. OC1 - Black/White
  12. OC2 - Blue/Black
Because this was an unexpected problem I had to cut the wires from my bypass plug in the center and solder to them. Had I time to order new PINs, using them would have been a better idea. I also removed the wire for the tach because my EMS controls the cars tach without it.
Now installation of the ByPass Plug will allow the car to run.
I believe the TwinFire Ignition uses the exact same plug and wire colors. So this may apply to that ignition box too.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
