wiring diagrams from ecu to engine
xtreme-elements
139
Jan 4, 2007
eighty four, Pennsylvania
:cry: i need the wiring diagram for the engine compartment.. i searched all over and everything that i found dont have what i need.. here is my situation.. i put a new motor in my buddys tsi... the new motor had an engine harness, his old engine caught fire so i figured... "cut the old harness out and solder the new one where i cut it"... well come to find out, the "new harness" that was cut from the salvage yard, was for a 90.. our car is a 1991.. so i decided to solder the "old" harness back in.. after i did that we have coil pack problems code 44 and some sensors dont work.. the car starts and runs then all of a sudden the check engine light comes on and it starts to runs like crap.. so i am needing a wiring diagram that shows where the wires actually should go and what colors they are from the ecu to the engine bay.. any help is apprecited:)
thank you i got a mitchell repair manual today.. the haynes manual sucks.. it dont show you any real info.. thanks again
