Wiring a Timer/Gauges...
Criscone240
Aug 23, 2004
Schenectady,NY, New York
ok ive got a 92 talon tsi awd turbo... Im getting a GReddy Turbo Timer and Autometer EGT Gauge (with an upgraded probe tho).. Anyways ive got my ECU out (just put in my SAFC2) and i wanna get the wires ready/done for the timer an EGT gauge.. Now anyone kno what wires come off the timer? im getting it w/ the harness for my car.. also is the EGT gauge just power,ground then the signal wire which taps into manifold?.. Also what wire on the ECU can i tap the A/F signal wire into i dont like how the wire goes all the way over into that tight corner i wanna tap into the ECU.. Let me kno please tired of havin my ECU hangin out for this long a## time.. But i dont wanna tear it all out again in 3 weeks an i want it tucked away set to go all my electronics done.. I dunno let me kno VFAQ.COM isnt helping me at all for the greddy timer or gauges..
On the A/F guage there is o2 sensor connector under the passenger side of the dash. remove the little kick panel and go through the wires and you will find a white plug with a single wire going to it. It is not plugged in to anything. Thats what i used to hook up my a/f guage. getting to the ecu wires was too much and to risky
For the turbo timer it's pin#18 it's the sixth in on the bottom row on the biggest plug. As for the power and ground use use the 12 volt of your ciggerate lighter and just find a clean point to ground . :talon:
