Wire up walboro 255 fuel pump?
Cagle101
Aug 30, 2009
Mount Holly, New Jersey
Bought used pump... Don't have instruction on how to wire it in.. Any help
Make sure you disconnect the rubber feed line from underneath the car. The fitting at the pump itself doesn't twist, skipping this step will split that rubber line in half.
No wonder it wouldn't break loose... I tried everthing... So just loosing the one at the bottom.. An it I'll come right off...
Yes, the hardline fitting underneath the car will disconnect from the rubber line. Once the bottom portion is disconnected you can twist the top rubber section right off.
