How do I "rewire"my 255lph fuel pump
Jonnynitrous
148
Nov 30, 2010
T bay, ON, Canada
theres got to be pics and diagrams some where
1. Disconnect battery.
2. Run power wire from the battery to the fuel pump location.
DO NOT CONNECT THE POWER WIRE TO THE BATTERY YET!
1G FWD: To tank under car. We recommend running the wire through the car and drilling a hole out to the pump loaction.
1G AWD: Rear driver side, in the trunk.
2G: Passenger side, under rear seat.
EVO VIII-IX: Driver side under rear seat.
Now that you have the wire run from the battery to the pump loaction the relay is wired as follows. We suggest soldering all connections.
#30 (blue wire) - feed wire from battery.
#87A (red wire) - not used.
#87 (yellow wire) - when cutting stock 12V pump wire, this is to the pump side.
#86 (black wire) - when cutting stock 12V pump wire, this is to the car side.
#85 (white wire) - chassis ground.
These are the numbers shown on the bottom of the relay where the prongs are. Now that everything is wired in properly, you may hook up the power wire. Have fun.
More information and detailed instructions can be found on VFAQ.
Ref: Streettuned Motorsports ( P.S. They sell a very nice rewire kit)
STM | STREET TUNED MOTORSPORTS | DSM | EVO | SUBARU | PERFORMANCE & DYNO TUNING
