1G wire harness
dsmluver98
75
Jan 6, 2008
Billings, Montana
ok so i was trying a wire reduction while i have everything out of the engine bay and i didn't think about marking everything before disconnecting because i thought well hey im just taking out the motor.. then i decided to take out the harness to make the bay look better since im cleaning EVERYTHING else LOL.. well i didn't mark it from the beginning.. i did trace from the o2 housing all the way to the transistor pack.. but there are plugs i don't know what they are for and im noticing that after i took this harness out that the guy before me hacked some things and now i just want to set this harness straight. but i have all the pictures you will need on my phone and can take more i do have the i phone but i still dont know how to post on here.. my uncle did it the last time and im unsure. i only need 5 or 6 plugs identified. any help will be appreciated my ask for my email or number and illl get everything to you
thanks DSM tuner
Josh
Items you will remove:
egr
a/c items
brake line fluid reservoir check
bcs
abs items
wiper items
defrost relay
cruise control
Keep:
mas
ptu
4x injectors
cas
o2 sensor
tps
ics
mpi relay
knock sensor
coolant sensor
coil pack
idle switch
power wire for fusebox
ok well i was looking at this harness and mine is totally different LOL at least i think so. unless the guy before me deleted things that i don't know about
my other thing i forgot to say was why do i wanna delete the
abs items
defrost relay
and can i delete the cruise control with still having the cruise control installed since i dont have the money for the non cruise cable?
abs items
defrost relay
Because you said this:
.. then i decided to take out the harness to make the bay look better since im cleaning EVERYTHING else LOL....
No. You can make your own cable without the still excesively long non cruise cable
ok im gonna try to post pics on here for my harness.. its nothing like what you gave me a picture of..
but i cant delete the abs until i get the delete kit right??
and this car is a dd so don't i need the brake line fluid reservoir and i kno i need the defrost right??LOL
and im completely lost on the cable :(
this is my wire harness.. i put it in order starting from the o2 all the way down to the MAF sensor
Ahhhh :confused: :ohdamn: :cry:
To the best of my knowledge, better pics would help:
1st pic
2 - emission solenoid
2nd[ pic
3 - fuel pump tester
I'm not sure of the rest its a clump and the pics is too small.
They would be:
-wipers
-mpi pack
-defogger
-knock sensor
-a solenoid or two
3rd pic
2- fuse box power
3 - starter i think
4th pic
3 - bcs
4 - goes on positive battery terminal
5 - cruise control
one thing to keep in mind when removing connectors is to watch if there are 2 wires going into a single pin on a connector. if that loop is broken it might cause an issue with something else potentially.
when i did my 3000gt wire tuck the main harness is 137 wires. i took masking tape and wrapped it arount the wire then wrote a number 2 times in a row and cut between the numbers so i didnt have to try to look for colors or where they went. this was really helpfull since i did a fuse box relocation a wire tuck and a battery relocation all at the same time.
once i wired it all up it was perfect the first start.
also having the shop manual with the wiring diagram handy is extreamly recommended as some wires might just randomly end because your car doesnt have certain features or they might be dry rotted and broken from age
this is just a pic of a wire harness repair and rewrap i did for a friend. just to get an idea how much this cleans up the look of the engine bay
couple of last sec notes. get high temp electric tape as the regular stuff has a melting poing of 150 to 180 degrees. this is under the op temp of the car. high temp or if at an automotive store wiring harness tape has a melting point of 220-300 degrees.
aslo along these lines, most ebay and colored plastic wire loom has a melting point of 100-130 degrees. where it will melt if touching something hot it will dry out really quick and crumble if you move it within a few weeks. only black wire loom comes in high temp and it usually has a white stripe down it. it is slightly more ridged but it will have no issues. the stock wire loom has a melting point of around 240-280ish. at least on the 3000gt so im going to guess the dsm is the same
