Window Trouble
PHLOORIT
Aug 13, 2004
Dallas, Pennsylvania
I'm having some window troubles. My side windows seem to not be sealing all the way. because water is still getting in. And when its semi cold out my defrosters wont work. I'll have them on full blast for 30mins and the windows still arent defrosting. I checked its not my heat because air is still coming out of the vents. What else could be the problem?
Check the alignment of your glass. You might also want to check the weatherstripping for any damage. As for your defroster, are you turning on your A/C when you use it? You need to in order to dehumidify the air and remove the moisture.
