Window rattle issue.....
Haha I think every 2 g has this problem.Take off the door pannel roll the window up about half way check the bottom of the glass and make sure that the bolts are all still on.Mine was horrible I took it apart and noticed one of the nuts that holds the bottom of the window was off.I put that sucker on and walla it was fixed.But now its been doing it again and I have been lazy.Good luck.I also think I have saw a ''how to fix the 2g window rattle'' post so try to search that.
will do, for now i gutta shut off my cpu so if anyone wants to post the link here for future refference for other newbies like myself that'd be cool, thanks for the help.
Be careful taking the interior panels off the door or you might break the mounting points that connect the window/doorlock control box to the door panel; they're very weak. When you get the panel disconnected, keep the weight of the panel off of the connector and then carefully disconnect the plug. If the control box mounting points break, it's not easy to rig up a fix, and your buttons will sink into the door when you push them and you won't be able to put your windows down very easily (button will hit something before the switch activates).
