Spyder window don't work 1999 Eclipse Spyder
leo1988
Aug 24, 2010
toronto, ON, Canada
I had a short behind the fender on the driver side and I repaired it but it blew a few fuses. I replaced the fuses, everything works but the windows. I don't know if there's a window relay or its the actual switch. Please help
i had a short behind the fender on the driver side and i repaired it but it blue a few fuses i replaced the fused everything works but the windows i don't no if threes a window relay or its the actual switch please help
Check for any more shorts in the wiring. Could be your motor/regulator itself is bad. They shouldn't be too expensive from a junkyard if thats the case.
yeah i had the same problem with my truck, a motor and or regulator should be an easy fix, not too expensive either
    • Sdcryan1
