Will this turbo work?
dsm_94_4ever
73
Mar 25, 2010
Roseburg, Oregon
OK so I know my car isn't anywere near ready for a turbo upgrade yet but I picked up this GARRETT for next to nothing.So my question is could I run this turbo on my car with the suporting mods and what kind of power could I make with it?I have a brand new 14b on my car right now no internal mods to the moter would it be better to work with the 14b antel its toast or if this GARRETT will even work on my car start thinking about buying front mount,injectors,pump and what ever else I might need?I know you can build decent power with the 14b but I really would like to use this GARRET it has no shaft play and really is in great shape kinda stuck in the middle not sure what to do.
That thing looks tiny, it might not even put out as much power as a 14b. Any turbo can be made to fit. Do you have a turbine housing for it?
Antique T3 Garrett from "?", complete with a Stage 1 turbine wheel.
You'll spend many hours and dollars to get this on your car only to have two things happen- a guy with a 14B will walk all over you, then this turbo will likely fail in the first year because of the 270* thrust plate along with the effects of using a turbo that is not designed for the wide oil pressure range on our engines.
That being said....cute paperweight you have there.
  • Wanted 6 bolt NT water pipe
    • chrisman287
