Will this throttle body work pics inside
talon187
1,043
Feb 11, 2003
torrington, Connecticut
Ok im not sure what year its from. I know its form a non turbo car and thats perfectly fine. my intercooling pipe comes stright out like that so it will work. Im going to be puting on a jdm intake manifold and hopefully this throttle body. I currently have a custom intake manifold and 75mm throttle body. im changing because im going with a smaller turbo and it will be over kill.
You cant just put it on though or the TB shaft seals will leak. They arent meant to handle boost. You need to pull it apart and put some o-rings in. Search around a few guys have done it. I actually run a 91 NA TB on my 6 bolt, so I have too.
How the heck do you pull that apart ? what type of 0 ring? any that is the right size? thats the part on the back of the throttle body with the green wire looking stuff is correct?
