75mm throttle body work with dsmlink??
97GsXfreak
137
Nov 15, 2004
Berkeley Heights, New Jersey
I have been searching the forums because I had aem in my car but i have now downgraded to dsmlink but I cant get the car to idle on its own and I'm thinking its because of my 75mm throttle body. It has the throttle position sensor hooked up and it has an IAT motor on the backside that isnt wired up...is there a way I can wire that up??? Is there any way to use this throttle body with dsmlink so my car will idle?? So basically right now just a tps is hooked up and the car wont idle I dont know what else could be the problem...at startup it sounds good and goes to the right rpm but then immediatly dies??????
Edit: I think its the IAT motor on the backside I dont know.... another thing if I start the car and hold the rpms at a certain rpm like 2k lets say..the needle on the rpm gauge will fluctuate around 2k but there wont be a change in the sound of the motor. I dont know what that means but maybe its something towards helping me idle.
