Will this camber kit get me to -2.5* camber in teh front?
bvass
447
4
Apr 23, 2006
Mesa, Arizona
Like the title says I want to run -2.5 degrees of camber in the front and I am wandering if this kit is enough to get me there - 35750-35760 - Camber Adjusting Control Arm Mounts - Ingalls Engineering Co., Inc.
Last year when I got alignment i was at about -1.4 degrees in the front. The car is lowered about 1.5 inches in the front on Koni/GC
If not what other kit should I get? I don't want adjustable ball joints and I have hared the offset bushings are a pain to adjust and do not last long.
This is a good article but as I mentioned before I do not want to go with the adjustable ball joints. Are the offset bushing my only other option? I like the SPC control arms but they are no longer available.
You can rotate the SPC anchor bolts (normally +1.5) to achieve -1.5 with a little grinding to the arm, as per the how-to. And than use the offset bushings.
Not sure how much negative camber the offset bushing will net by themselves.
Edit, according to RRE's website, the offset bushings are +/- 1 degree. So you would have to use two kits in conjunction.
They are new anchor bolts for the upper suspension arm, with offset bushings. You rotate the bushing to vary the positive camber.
SPC Adjustable Front Camber Anchor Bolts 95-99 Eclipse/Talon - CI Motorsports
You use the SPC anchor bolts for +1.5 camber, and reverse them, giving you -1.5 camber. It is the one on the right, in the link above. A little grinding to the inner part of the arm is needed, however.
The anchor bolts for +3.25 camber "turn out" to much to be reversed. A lot of grinding to the arm would be needed.
Thanks for the link and information :)
Or you can modify your stock upper control arms: LINK
I've thought long and hard about this, but just get nervous about it weakening it too much for road racing. I think it's something I could do on a spare set though. I bet there's a way to calculate the amount needed to cut to achieve the desired camber, but I'm not going to be the one figuring it out unfortunately. :coy:
When I finally get new wheels, I'm going to a non-tuck setup like yours. How much front camber do you think is optimal on a road-race, r-comp, non-tuck setup?
those offset anchors only gave me -1; i also cut/welded stock A arms to get more negative =)
I was running -3.0º front with modified control arms, 750 springs and 245's on 8" wheels. But after I switched to GC arms, 900 springs, and 275's on 10" wheels, I found that -3.0º was too much. Braking had suffered. So now I'm running -2.5º.
You really aren't weakening them if the welder knows how to weld. In most cases a weld should be stronger than the base material with steel. If you haven't already boxed in the arms like he's done though, I'd do that after you cut them and weld them back in place. Should give you a very strong arm when you're done.
The weld will be stronger than the material, but the HAZ will be weaker. I don't foresee it being an issue, it's just a mental game where it's simply one additional modification to worry about. I'd be doing the welding (MIG) myself. Those are stock arms, they're "boxed" like that from the factory.
Since I'm bumping this, could the same thing could be achieved by simply redrilling the hole in the arms? The area is a bit smaller, but it's also closer to the boxed area, and could be reinforced easily enough. I like this idea better than the cut/reweld.
:hmm:
Old thread I know, but did you have issues with toe running -3* (tie rods being too long)? and were you on street tires or race compound?
