Will the ebay 16g turbine housing fit the mhi 16g?
LOL I was just looking at that before I saw this thread. I think it would fit. Nothing wrong with that for a 16g.
I was going to ask would that same turbine housing fit a td06h 20g?I have a buschur 20g and my turbine housing are stripped out. let me know :)
No. The ebay one is a bit smaller than the mhi one. I already tried, LOL.
Are you sure you tried it on the right turbo?
I've installed eBay turbine housings on MHI turbos on more than one occasion. It's a great way to replace a cracked MHI housing with one that came from a turbo which can't last more than 200 miles. The housings themselves are decent....I have yet to see one crack, but the threads tend to pull out of them rather easily if you're not careful.
The one thing you'll run into is the locating pin on the MHI center housing is much smaller than the one that fits the knockoff turbine housing. You can:
- Use the small MHI pin and make sure it's centered before you tighten the v-band
- Drill the hole in the MHI center housing to accept the larger pin of the knockoff turbine housing.
If the turbo you're installing it on has a TD05H turhine, yes. It will NOT fit MHI turbos with TD04H, TD06 or TD06H turbines.
so what about using an mhi turbine housing on an evo 3 turbo LOL, im trying to get my setup back on the road. Im saving for a fp green so i dont want to spend alot and have a spare mhi turbine housing sitting around. Just want to know if it will work before diving into the project
