Will not stay running (idle issue with video)
Hmm, might be the o2 sensor. The car starts up in open loop and after about 30 seconds closed loop kicks in, adjusting fuel based on feedback from the front o2 sensor...that's my initial guess. Any check engine light?
Both O2 sensors are new, although I did delete the cat with my new downpipe.
Yes the car will start right back up and do the same thing again
NO CELs
If I unplug the MAF it will run all day. I am trying another ecu right now and I just switched MAFs.
Same thing with the other ECU
I was able to pull a log: Here is my 1st run (Maf plugged in, cat 02 sensor is unplugged)
Live Data
Number of DTCs stored in this ECU 0
Fuel system 1 statusOL-Drive
Fuel System 2 status--
Calculated LOAD Value(%)23.5
Engine Coolant Temperature(¡£C)36
Short Term Fuel Trim -Bank 1(%)0.0
Long Term Fuel Trim - Bank 1(%)0.0
Engine RPM(rpm) 894
Vehicle Speed Sensor(km/h)0
Ignition Timing Advanece for #1 Cylinder(¡£)6.0
Intake Air Temperature(¡£C)19
Air Flow Rate from Mass Air Flow(g/s)6.07
Absolute Throttle Position(%)6.3
Location of Oxygen SensorsB1S12--B2S----
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)1.275
Short Term Fuel Trim Bank 1-Sensor 1(%)0.0
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.080
Short Term Fuel Trim Bank 1-Sensor 2(%)0.0
OBD requirements to which vehicle is designedOBDII
Fuel system 1 statusCL
Calculated LOAD Value(%)21.6
Engine Coolant Temperature(¡£C)37
Short Term Fuel Trim -Bank 1(%)-2.3
Engine RPM(rpm) 1359
Ignition Timing Advanece for #1 Cylinder(¡£)11.0
Air Flow Rate from Mass Air Flow(g/s)24.11
Absolute Throttle Position(%)0.0
Short Term Fuel Trim Bank 1-Sensor 1(%)-5.5
Short Term Fuel Trim Bank 1-Sensor 2(%)-6.3
Calculated LOAD Value(%)14.9
Short Term Fuel Trim -Bank 1(%)-8.6
Engine RPM(rpm) 1683
Ignition Timing Advanece for #1 Cylinder(¡£)19.0
Air Flow Rate from Mass Air Flow(g/s)26.82
Absolute Throttle Position(%)38.8
Short Term Fuel Trim Bank 1-Sensor 1(%)-12.5
Short Term Fuel Trim Bank 1-Sensor 2(%)-13.3
Calculated LOAD Value(%)58.8
Engine Coolant Temperature(¡£C)38
Short Term Fuel Trim -Bank 1(%)-14.1
Engine RPM(rpm) 1625
Ignition Timing Advanece for #1 Cylinder(¡£)12.0
Intake Air Temperature(¡£C)20
Air Flow Rate from Mass Air Flow(g/s)5.15
Absolute Throttle Position(%)3.1
Short Term Fuel Trim Bank 1-Sensor 1(%)-14.1
Short Term Fuel Trim Bank 1-Sensor 2(%)-14.1
Calculated LOAD Value(%)11.8
Engine RPM(rpm) 1238
Ignition Timing Advanece for #1 Cylinder(¡£)5.0
Air Flow Rate from Mass Air Flow(g/s)4.90
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.060
Calculated LOAD Value(%)0.0
Engine Coolant Temperature(¡£C)39
Engine RPM(rpm) 0
Air Flow Rate from Mass Air Flow(g/s)0.00
Engine RPM(rpm) 113
Ignition Timing Advanece for #1 Cylinder(¡£)10.0
Air Flow Rate from Mass Air Flow(g/s)24.83
Absolute Throttle Position(%)31.4
Calculated LOAD Value(%)12.2
Engine RPM(rpm) 1757
Ignition Timing Advanece for #1 Cylinder(¡£)20.0
Air Flow Rate from Mass Air Flow(g/s)7.09
Calculated LOAD Value(%)41.6
Engine Coolant Temperature(¡£C)40
Engine RPM(rpm) 1976
Ignition Timing Advanece for #1 Cylinder(¡£)29.0
Air Flow Rate from Mass Air Flow(g/s)12.47
Absolute Throttle Position(%)4.7
Calculated LOAD Value(%)27.1
Engine RPM(rpm) 851
Vehicle Speed Sensor(km/h)5
Air Flow Rate from Mass Air Flow(g/s)5.92
Engine Coolant Temperature(¡£C)41
Engine RPM(rpm) 808
Vehicle Speed Sensor(km/h)6
Air Flow Rate from Mass Air Flow(g/s)7.86
Engine RPM(rpm) 765
Vehicle Speed Sensor(km/h)7
Air Flow Rate from Mass Air Flow(g/s)4.49
Calculated LOAD Value(%)27.5
Engine RPM(rpm) 734
Vehicle Speed Sensor(km/h)4
Air Flow Rate from Mass Air Flow(g/s)4.53
Calculated LOAD Value(%)29.4
Engine Coolant Temperature(¡£C)42
Engine RPM(rpm) 699
Vehicle Speed Sensor(km/h)3
Calculated LOAD Value(%)29.8
Engine RPM(rpm) 582
Vehicle Speed Sensor(km/h)1
Air Flow Rate from Mass Air Flow(g/s)4.62
Calculated LOAD Value(%)29.0
Engine Coolant Temperature(¡£C)43
Engine RPM(rpm) 683
Vehicle Speed Sensor(km/h)2
Ignition Timing Advanece for #1 Cylinder(¡£)21.0
Air Flow Rate from Mass Air Flow(g/s)4.67
Engine RPM(rpm) 714
Air Flow Rate from Mass Air Flow(g/s)8.62
Engine RPM(rpm) 652
Ignition Timing Advanece for #1 Cylinder(¡£)18.0
Air Flow Rate from Mass Air Flow(g/s)4.81
Calculated LOAD Value(%)46.3
Engine Coolant Temperature(¡£C)44
Engine RPM(rpm) 1480
Air Flow Rate from Mass Air Flow(g/s)9.45
Absolute Throttle Position(%)3.9
Short Term Fuel Trim Bank 1-Sensor 2(%)-0.8
Short Term Fuel Trim -Bank 1(%)-1.6
Engine RPM(rpm) 906
Ignition Timing Advanece for #1 Cylinder(¡£)13.0
Air Flow Rate from Mass Air Flow(g/s)4.75
Short Term Fuel Trim Bank 1-Sensor 1(%)-3.1
Short Term Fuel Trim Bank 1-Sensor 2(%)-3.1
Calculated LOAD Value(%)42.0
Engine Coolant Temperature(¡£C)45
Short Term Fuel Trim -Bank 1(%)-4.7
Engine RPM(rpm) 988
Air Flow Rate from Mass Air Flow(g/s)11.08
Absolute Throttle Position(%)11.4
Short Term Fuel Trim Bank 1-Sensor 1(%)-6.3
Calculated LOAD Value(%)52.5
Engine RPM(rpm) 1832
Intake Air Temperature(¡£C)21
Air Flow Rate from Mass Air Flow(g/s)14.32
Absolute Throttle Position(%)23.1
Short Term Fuel Trim Bank 1-Sensor 1(%)-10.9
Short Term Fuel Trim Bank 1-Sensor 2(%)-11.7
Calculated LOAD Value(%)54.5
Short Term Fuel Trim -Bank 1(%)-12.5
Engine RPM(rpm) 1195
Air Flow Rate from Mass Air Flow(g/s)14.71
Absolute Throttle Position(%)12.9
Short Term Fuel Trim Bank 1-Sensor 1(%)-15.6
Short Term Fuel Trim Bank 1-Sensor 2(%)-15.6
Calculated LOAD Value(%)52.2
Engine Coolant Temperature(¡£C)46
Short Term Fuel Trim -Bank 1(%)-17.2
Engine RPM(rpm) 968
Vehicle Speed Sensor(km/h)9
Ignition Timing Advanece for #1 Cylinder(¡£)9.0
Air Flow Rate from Mass Air Flow(g/s)13.67
Absolute Throttle Position(%)18.8
Short Term Fuel Trim Bank 1-Sensor 1(%)-19.5
Short Term Fuel Trim Bank 1-Sensor 2(%)-19.5
Calculated LOAD Value(%)54.1
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.08----------------------
Engine Coolant Temperature(¡£C)47
Engine RPM(rpm) 1207
Engine RPM(rpm) 1140
Ignition Timing Advanece for #1 Cylinder(¡£)14.0
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)1.27Short Term Fuel Trim Bank 1-Sensor 2(%)-22.7
Calculated LOAD Value(%)21.2
Short Term Fuel Trim Bank 1-Sensor 1(%)-23.4
Calculated LOAD Value(%)51.4
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)1.27Short Term Fuel Trim Bank 1-Sensor 2(%)0.0
Calculated LOAD Value(%)37.3
Engine Coolant Temperature(¡£C)48
Engine RPM(rpm) 1312
Engine Coolant Temperature(¡£C)49
Vehicle Speed Sensor(km/h)17
Air Flow Rate from Mass Air Flow(g/s)50.17
5
Engine RPM(rpm) 1902
Engine Coolant Temperature(¡£C)50
Vehicle Speed Sensor(km/h)40
Air Flow Rate from Mass Air Flow(g/s)33.26
5
Engine Coolant Temperature(¡£C)51
Vehicle Speed Sensor(km/h)46
Air Flow Rate from Mass Air Flow(g/s)21.32
5
Engine Coolant Temperature(¡£C)52
Engine RPM(rpm) 1132
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.06----------------------
Engine Coolant Temperature(¡£C)53
Engine RPM(rpm) 894
Engine Coolant Temperature(¡£C)54
Engine RPM(rpm) 667
Intake Air Temperature(¡£C)18
Vehicle Speed Sensor(km/h)19
Engine Coolant Temperature(¡£C)55
Engine RPM(rpm) 519
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)1.27Short Term Fuel Trim Bank 1-Sensor 2(%)-1.6
Calculated LOAD Value(%)34.1
Engine Coolant Temperature(¡£C)56
Engine RPM(rpm) 785
Engine RPM(rpm) 804
Engine Coolant Temperature(¡£C)57
Air Flow Rate from Mass Air Flow(g/s)4.43
5
Engine RPM(rpm) 531
Engine RPM(rpm) 914
Engine Coolant Temperature(¡£C)58
Vehicle Speed Sensor(km/h)8
Calculated LOAD Value(%)27.8
Ignition Timing Advanece for #1 Cylinder(¡£)22.0
Engine Coolant Temperature(¡£C)59
Engine RPM(rpm) 1718
Engine RPM(rpm) 2296
Engine Coolant Temperature(¡£C)60
Engine RPM(rpm) 1812
Short Term Fuel Trim Bank 1-Sensor 1(%)-4.7
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)1.27Short Term Fuel Trim Bank 1-Sensor 2(%)-10.2
Calculated LOAD Value(%)53.3
Engine Coolant Temperature(¡£C)62
Engine RPM(rpm) 1089
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)1.27Short Term Fuel Trim Bank 1-Sensor 2(%)-18.8
Engine Coolant Temperature(¡£C)63
Engine RPM(rpm) 0
Engine RPM(rpm) 0
Vehicle Speed Sensor(km/h)27
5
Engine RPM(rpm) 0
Vehicle Speed Sensor(km/h)22
5
5
Ran into the same issue once but mine was due to fuel pressure..... Wally 255 and AFPR fixed that for me. What happens if you try and give it a little throttle when it's about to cut off?
She comes back to life. I was thinking it was my fpr. I have a wally 255, just not installed. I did order another stock fpr yesterday. we'll see if that was the issue.
did you reset your timing . if you did does it run any better . do you have anything to monitor the sensors to see what they are doing . make sure your o2 is switching from lean to rich . how is your fuel pressure . do you have any vacuum leaks . if your o2 is stuck rich then you might have a vacuum leak .
I took it for a drive yesterday down the road (maybe 1/2 mile). I pulled back into my driveway and I have been unable to get the car to start again. It cranks and cranks, but it will not catch. It will turn on then instantly die. I'm confused, the car drove down the road yesterday.
I don't know. I don't have a gauge. I just threw in a working wally 255 ( I know it's too much, but I know it works) Same issue. I tested spark and if my injectors were getting signals - both checked out fine. If I give it gas, it will start, but will die if pressure is taken off of the pedal. Are you still thinking fuel pressure? I have a new regulator coming, should I get a Fuel Pump relay too?
I'm also going to replace the MFI Relay
So your getting spark and fuel but still cutting out? Check the tps yet?
Also crank and cam position sensor
I'm thinking it may be a fuel pressure problem. Car will not start unless I give it a lot of gas.
he car used to start pig rich, but when it went into closed loop the fpr may not have been able to maintain pressure? Thoughts?
I got it to start and idle. My throttle set screw was too far in and my timing was off bu 1 tooth. I fixed those 2 issues and it started right up.
If you read through my data log you will see that the Absolute Throttle Position is at 0% when I am not moving. It should be around 2-3% to keep it running.
