Will it work?
Blackmonster
Aug 8, 2011
Waterford, Pennsylvania
I got a 93 talon es with the motor torn apart for cheap. I found a 4g64 out of a 95 galant. Im trying to get the talon runing for cheap. Will the 4g64 block out of a 95 galant work with my head?
Like ^he said and if it does you Just gotta do some tricks with the timing. I'm pretty sure there is a vfaq with a walkthrough and parts list. Have fun.
What is wrong with the engine that is torn apart? You can rebuild one of these engines for real cheap if you play your cards right. Usually you can hone the cylinders, polish crank, clean everything and assemble with new rings, bearings and gaskets and spend a few hundred dollars if everything is in spec.
I say rebuild with some NPR 2g pistons and start planning for a 14b, most parts can be had for a good price but DON'T cut costs on the gaskets or you will regret it.
