will chrank but not start
eclipse12
Oct 2, 2008
Baltimore, Maryland
hello everyone my name is Brad im new to the dsm world im havein some problems with the 96 eclipse gs i really need some help asap i car will chrank but not turn over the fuel pump is not turnin on at all when the key is on i dont know whats up someone help me please
Yeah i would have to agree with 19tsi95awd check the fuel pump connector and check your fuses before you do anything else. IF! and when you replace your fuel pump remember to replace the filter as well because alot of times the fuel pump will fail due to a clogged filter. You wouldnt wanna buy a new pump and have that fail right away because of a 10 dollar part
Also when you turn your key over listen to see if your fuel pump is coming on. If not check the fuel pump relay, you can switch it with one that has the same prongs, see if that works. If not, check the connector on the wiring harness, and on the fuel pump itself. When all else fails, go to Advance Auto Parts and buy a new fuel pump.
Check and see if you're getting spark. If no plugs are sparking, check your CAS. Search if your friend. :)
