Will a 190LPH be enough?
greddy_1700
1,036
91
Aug 27, 2006
Regina, SK, Canada
Hey, I have a friend willing to give me a brand new Walbro 190LPH pump for free and I was wondering if it would be enough for my setup.
I am running a built 2.3L with 8.8:1 compression and BC 280 cams, 1050cc injectors, and a FP 20g. Now obviously I know those injectors are overkill for such a pump, but is it feasable to use this pump, rewired, to support roughly 23 psi?
I know that a 255HP would be ideal, but this is free:D
Oh, forgot to add, I will be using ethenol blended 94 Octane fuel.
I guess Im going to ask now. My profile is up to date other than I will have a FMIC and wideband.
Would a 190 LPH rewired be okay for 20-23 psi?
Well if its free then take becasue thats still an improvement, but dont really dont expect it to be able to throw enough fuel for the 20g and that amount of boost, keep it conservative like at 15. Rewire it too, that way you get the most out of it until you get a 255 and fpr
I would recommend the 255hp if you plan on pushing the 20g to its limits. But 190lph are generally good up to 325-350whp. You could always take the 190lph for free and then sell it for something
Should work if its rewired. I'm running a Denso 150 LPH rewired pump on an EVOIII 16g @ 28 psi with 650cc injectors. I'm pulling 44 lb/min with no problems though I'm nearly running out of fuel at my current a/f ratios. I think 23 psi will be fine.
  • Wanted 6 bolt NT water pipe
    • chrisman287
