will 2g piston rings fit 6 bolt block?
If you are asking if 2G piston rings will fit on 2G pistons, mounted to 6 bolt rods and installed in a 6 bolt block on a 6 bolt crank, the answer is yes. You must get the rods machined to fit the 2G pistons though because the 1G wrist pin is 21mm and the 2G is 22mm
