Wierd thud under car ?
chanley talon
773
14
Nov 10, 2005
Spencer, Indiana
I believe im having driveshaft isues? When i accelerate hard it feels like somone is knocking underneath the car . Is their a fix for this somewhere and what is that round center section called? Where the driveshaft meets together? Im not talking ujoint? Its rubber ?
Please help .....thank you ......very much.
Propeller Shaft Center Bearing Part Number: MB505495
Spacer Set (x2) - MB241174
OEM Nuts (x2) - MF445005
OEM Washers (x2) - MF450406
Did you try the vfaq window weld fix? Your old nuts and washers should be fine...But there are the part numbers just in case. You can also find them on the third link I posted.
