Wierd sound on boost
britdog
153
Jun 27, 2011
tiffin, Ohio
OKay so i had stopped at a light and went to get on it after the light turned green. It sounded like something scrapped the ground when i got on the throttle. you could feel it on the pedal and it just sounded like a scrapping noise. i also have a like cracking noise when i push the break pedal but only sometimes you can hear the crack. what is going on? :ohdamn:
what kind of cracking sound? can you feel it in the brake pedal, steering wheel? is the sound inside the car, or outside? is it louder the harder you push? the other noise sounds like the turbo may be worn out, def agree with checking shaft play. on the turbo.
Does it seem speed related or rpm related? It's hard to speculate, but assuming it's speed related, probably a drivetrain/chassis issue.
<ul>
<li>I'd jack up the front end on stands and turn and rotate the wheels (ignition unlocked/out of gear).
<li>Check CV joints.
<li>Pull off tires and check brake system.
<li>Exhaust ground clearance?
</ul>
Good start. Good luck.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
