wierd fluid sound help??
91gsdohc
1,099
Jan 25, 2010
around, Connecticut
91 tsi awd................. when i start my car i can hear fluid kind of "splashing around" and when i hit the gas the "splashing around" gets louder according to how mush throttle i give it. i cant hear it that well out side the car because it to loud to hear but when im inside i hear it right behind where the cd player would be any ideas? also since that right where the ac is i want to let you know that there is no belt attached to that pully if that means anything something else i dont know if matters but im going to give all the info i have on the car it is running 16g no supporting fuel mods and there is a crack in the valve cover that i just jb welded any help/ideas is wonderful thank you
LOL thats when you change the it or drain the coolant. but for now leave the petcock alone and just fill it with water for now and as its running fill it up as it goes down.... And these cars get up to temp very fast because of the low cooling capacity and small cooling passages. My 420a got up to temp fast, my exs 420a got up to temp fast and my buddys tsi awd gets up to temp very fast.
thats good to know i was getting worried about the temp rising so fast so ill back here tomorrow and let you all kow if that solves the issue LOL and thanks
No problem welcome to the DSM world. Its a whole different monster=)
im not that new back when i joined the site i had a 91 gs ecu went replaced it a week later the tranny went now im back at the top of the line with turbo awd LOL but thanks
Just one other piece that you might consider if the heater core is plugged, but you can try to flush it out by draining some coolant from the system and disconnecting the hoses from the heater core and using a semi powerful stream of water to push water in both directions of the heater to attempt to remove any debris from the core...
im about to run it threw some heat cycles now but if that dont work how do i do what your talking about
i tried to run it threw teat cycles and the water never went down it just stayed at the top.... and i have to say i was a little confused when the cap wasnt on the radiation LOL
the water should have moved or came down at least some. but any way to what alaskandsm said, To take off the heater core hoses you would have look on the fire wall just behind the where the throttle body connects to the intake and look down just a bit and you will see two big hoses that go into the fire wall and those are your heater core hoses, drain your coolant and take them hoses off and find a long 5/8 heater hose and get a garden hose and hold it to the heater hose and let it run as its flowing watch to see what comes out you might be surprised ROFL what comes out. Reconnect every thing and fill it up and see what happens.:hellyeah:
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
