Wideband o2 , With Logger
RockSolidGST
151
Mar 23, 2005
Boston, Massachusetts
Is there any way to use the analog out on the Wideband ( AEM UEGO ) and somehow log it threw the Datalogger , instead of logging the narrowband signal?
I did a search a few times , I know there must be a way
A little guidence is all i need thanks :thumb:
99gst_racer said:
Cut the wire from the rear O2 sensor to the ECU. Then run your 5V output from the WB to the ECU. Then when you log the rear O2 voltage, it will be the Wideband readings. This is how I had mine a couple years back.
That's cool. I didn't know you could do that. :thumb:
