1G Why you dont overboost a fp turbo
SasaniFab
2,432
788
Dec 1, 2013
Mexico, Connecticut
So I got a message today from my buddy who purchased the fp green off of me awhile back. The turbo had less than 1k on it mind you. His car is pretty serious and was just switched over to automatic. This is why you dont go over 30psi on a stock framed turbocharger.
But those turbos are doing 30+ now right? Im no turbo expert but im sure something else must have been wrong!
Id like to see the lifespan of the turbo boosted 30+ psi for extended periods of time. Looks like the wheel exploded
The shaft and the nut are intact.... looks like what happens when you overspeed a cd.
Like to hear some opinions
It looks like a wheel failure to me from a manufacturing defect. The large DSM frame turbos are boost limited, not because of wheel failure, but because of thrust failure due to the heavy rotating assembly on the same 14b thrust hardware. That was the reason they pushed for the BB versions if running higher boost levels.
I highly doubt this would happen so quickly just because of the amount boost being run. Otherwise, FP would be out of business. Now, if this were over 4 years or some extended period then it's possible.
Looks like the 90 degree elbow is blown out. I wonder if it was a serious boost spike that killed it. Also... what's the strand of wire for?
..Misinformation as usual. @Kapok6 @donniekak
Both of you were high 40+ for a while on FP turbos right? I'm 99% sure that's whoever took it apart didn't put it back together properly. Never seen an FP turbo fail. I'm running 30psi right now on a v1v68hta with zero issues, have been for months.
Usually a compressor coming apart isn't going to knock the cover off as the energy is directed radially from the shaft centerline, not in a thrust direction.
However a compressor cover coming off can easily wreck the compressor wheel. I have actually seen Mitsubishi style compressor covers blow off before.
I've never had any issues using an fp turbo within their design parameters.
I'm calling bs. It looks like the compressor housing wasn't seated all the way, eventually came off at high boost, and the rest is history. Failures due to high boost result in thrust hardware failure, as mentioned earlier.
Guys if the turbo was running through an entire racing season untouched and suddenly the wheel explodes , the owner says the shaft still spins freely. I havent seen it myself but if the wheel exploded is it possible to throw the cover off? The nut is still visable?
Thats not from boosting 30 psi. Looks like the compressor cover wasnt attached correctly and came off damaging the wheel. That large snap ring can be a pita to fully seat if the turbo is still in the car when trying to install it
^This.
It's a commonly know issue, which causes exactly the damage pictured. If the snap ring were seated properly, the compressor housing would still be attached to the cartridge. The compressor exploding should not dislodge the compressor cover, no matter how much you're overspeeding the turbo.
Id like for fp to chime in
Well, you'll be waiting a while. FP hasn't provided feedback or technical advice here on the forums for quite some time, nor are they a supporting vendor anymore. If you'd like their feedback, you'll need to get it via other means.
^This.
So what your saying is that if he didnt mess with the compressor cover, its possiblethat it wasnt assembled correctly? I never took it off or had
To clock the housing. Ill ask if he did.
It may not of been you, it could of been him playing around with it, these normally have dowel pins so if it was a fraction off it can not let it seat correctly, my guess is the comp cover as many turbos that go bang i dont ever see that pull the comp cover off!
Doesnt make sense..... the turbo was doing fine then all of a sudden it came unseated? He had been racing with the turbo all season, never took it apart? You dont have to? The turbo comes ready to go
Either way, the argument isnt if u can boost them to 30psi or more..... they are simply not engineered for those types of boost pressures. Maybe the snap ring worked its way loose and blew off into the compressor blade.
No idea on what they are rated to, snap rings are stong, used in alot of thi gs from suspension and wheels etc so they do well, 30psi sbould not be an issue, we can only guess and assume at the moment but fp will tell him exactly why it came off, take a look at this https://www.smalley.com/ring-design/load-capacity is shows how strong snap rings are,
