turboglenn
- 6,375
- 123
- Nov 5, 2007
RIpley,
West Virginia
For years (over 10) I've been installing and tuning full stand alone ECU's and only in recent years have there been any with a provision for knock counting (save for certain expensive systems and some specialty setups that were available for grand nationals)
I've got well over 2 hundred stand alone installs to my name with probably 40 or more being on DSM's, and only a dozen or so that were full stand alones with knock on those dsm cars (mainly AEM ECU's)
Now why i am bringing this up is everyone is so afraid of a little knock count and how severely the DSM ecu reacts to it, and i can only ask why??
A recent thread brought me to bring this up, but out of all the cars I've tuned, NONE have died from a result of detonation or a lean situation. And only one has blown up in the past 6 years and that was because the wastegate blew the vac line off on the preious run and for the next entire 1/4 mile the car ran as much boost as it could. I remember the owner saying "it pegged past 30 psi" and i had even put a failsafe in there because we had not tuned it that high, so the timing was pulled to 8* under that The only reason i can think that it blew was either a lack of ARP fastners on the heads or we simply ran out of injector even firing them at full duty cycle and it popped from lack of fuel supply. We were only running 850's
I will normally run a DSM with at least 16 - 20* advance under full boost(17-20psi) on only pump gas depending on the overall setup, CR, AFR and turbo size. ( now i know 16-20 is about what the factory ECU offers up, but it is a safe and good range to use, so i do when on pump gas, but i have gone higher, but with minimal result it wasn't worth the chance on a DD tune) Race gas is a whole different ball game. I just don't get why everyone is so afraid of the Mitsubishi knock sensor and its hypochondriac behavior. Mitsubishi set the ECU's up to keep the car safe no matter what dumb-ass drove it, meaning it's made for people to accidentally put 89 octane in, beat the piss out of, not have the oil changed on a regular basis and still last 100k miles. The motor is not going to fall apart at 4 counts of knock on the mitsu sensor, let alone 1.
When i was taught to tune cars on the dyno by our former local dyno shop owner we were doing a lot of ACCELL DFI Gen V systems. The guy ( E.J. a.k.a. Eugene ) has now sold the shop to a member of the local corvette club, and I'm teaching him stuff every time i go there. But anyway, i was taught to tune with no way of measuring knock except inspecting the spark plugs, listening to the engine's overall behavior and even a way to watch the exhaust to look for knock signs in it. Severe knock will kill any motor(save for diesels), but all motors make noise, and all 4g63 motors being pushed hard will have noise that the factory mitsu sensor will pick up as knock. Especially if you have JE pistons
Now, don't get me wrong, products like the MSD and my favorite the J&S knock sensors are very nice for keeping you in the safe areas, because if you set off one of them (the MSD especially) you are knocking pretty good and need to let out of it NOW. And yes, since the products are there, i do monitor knock through electronic devices mainly when tuning on the dyno(unless it's a car i'm really familiar with), but the mitsu sensor is about as trustworthy as a politician so i don't get why everyone puts so much faith in it.
DIsclaimer for those who are pissed off at this point
Now for those of you who run a system that utilizes a factory ECU and have to watch for knock or you'll lose performance, I understand why YOU have to watch it so carefully, and maybe that's why i see so much about it. I can truly sympathize with you because I've been there before and going full stand alone took the biggest pain in the ass part of tuning a Mitsubishi away and I'm still very happy about that one little thing being out of my hair. Even the Grand Nationals stock ECU doesn't cry wolf every time there's a fart in the engine bay
But for you guys running megasquirts, AEM's and other ECU's (Motec, Haltech, Autronic ) Don't be afraid to run the timing up a little, and if you need any advice on anything because you didn't do the setup or tune on your car/ECU, Or, if you just wanna BS stand alone stuff, PM me and I'll help you out the best i can or we can just talk ECU's. I don't know everything, but I've been through quite a few ECU barbeque's in my time, and would be glad to help anyone out that asks. Given you have the ability to behave like an adult and listen to advice that is.
:Now for those of you who run a system that utilizes a factory ECU and have to watch for knock or you'll lose performance, I understand why YOU have to watch it so carefully, and maybe that's why i see so much about it. I can truly sympathize with you because I've been there before and going full stand alone took the biggest pain in the ass part of tuning a Mitsubishi away and I'm still very happy about that one little thing being out of my hair. Even the Grand Nationals stock ECU doesn't cry wolf every time there's a fart in the engine bay
.But for you guys running megasquirts, AEM's and other ECU's (Motec, Haltech, Autronic ) Don't be afraid to run the timing up a little, and if you need any advice on anything because you didn't do the setup or tune on your car/ECU, Or, if you just wanna BS stand alone stuff, PM me and I'll help you out the best i can or we can just talk ECU's. I don't know everything, but I've been through quite a few ECU barbeque's in my time, and would be glad to help anyone out that asks. Given you have the ability to behave like an adult and listen to advice that is.
. Somany tuners in other relms have done this for years. I'm not saying that you shouldn't use a knock sensor in your tuning exercises, but if nothing indicates you SHOULD have knock and you know your boost and setup is what is acceptable, then there is still only one assumtion
)... mid 10's afr's, conservative timing, etc...
