Why does my boost change so much?
TooFastTooG
521
6
May 12, 2004
Plainfield, Illinois
Hey guys just had a quick question, I notice that the psi in my car changes alot. It varies anywhere from 7-13 psi. It seems to change threwout the day. My car is stock besides exhaust and a boost gauge. Any help would be apreciated. :dsm:
You going by the stock or the aftermarket? May fluctuate b/c of throttle position ROFL . Ok on to more serious answer. Fluctuating/loose actuator? Could have something to do with a faulty wastegate. Do you have a mbc? If so take the screw out and look at the spring, I bet its stuck sideways, happened to me and id get anything from 10-20 psi in a 2nd gear pull.
Also check the hose routing to the wastegate actuator.
You said it fluctuates throughout the day... does it change inconsistently or follow any pattern?
