who's running the magnus sheet metal intake mani?..read
WhiteCharisma
273
Jul 7, 2003
Hialeah,
wassup guys.. when you put this intake manifold on where would u put all the sensors that go on the stock intake manifold and all the vaccum lines and the coil packs that go on the stock one ..the magnus one does'nt come with anything...how would you install this manifold onto the car a 2G ?.. :confused:
its a race-type intake manifold so therefore you don't use your stock sensors (MAP) I believe.
You also don't need all the vacumn lines... Installation is fairly simple.
I would mount the coil pack near your strut tower or use a coil-on-plug setup
but u need the vaccum line for the blowoff valve....so this isnt a direct bolt on and isnt recomended for the street?.
you can get a blow throu set up
