who makes a good afpr?
Hesh724
373
Feb 7, 2009
Hopewell, Pennsylvania
I am still running stock injectors but i have a 255 in the trunk in preperation for bigger injectors and all that stuff. but i want a fpr that i can still run till i do get bigger injectors and stuff. oh and if i get bigger injectors can i just get an eprom ecu chipped for bigger injectors instead of running all that maf hack crap. and without buying a aem fuel management or piggy back? thanks for any input.
AFPR-
Aeromotive
Fuelab
Any AFPR that the vendors of this site sells would be sufficient. You don't necessarily need to hack your MAF or a complete EMS system. You can run SAFC/SAFC II and that would be fine. I ran RC 550cc and PTE 680cc injectors w/o AFPR and my car ran great, just rich.
If you have/are getting an EPROM ECU, may just be worth it to get ECMLink. I see V2 (DSMLink) going for pretty cheap.
Yes sir. Clickity----> www.dsmchips.com
At a minimum, some type of logging/monitoring should be available and you may still want to get a piggyback with a DSMchip.
Chipped to +30% fuel map due to 8.5/1 pistons, fuel cut elimination, and check engine light comes on as shift light. i think its technicaly stage 1. so if i understand right if i have an ecu chip that knows im running diffrent injectors it will be all i need? ofcourse the monitoring stuff still guages etc.. what is the largest size injectors that the maf will be able to keep up with?
What are some advantages of a AFPR? If you chip it, wont it be able to adjust it via the chip? I'm still new to chips/tuning.
Also, the CEL as a shift light sounds pretty clever.
the cel as a shift light would be interesting but what happens when it really is something? i would prefer a real shift light.
as for afpr's... you don't need them to be chipped, thats what the A is for. it is Adjustable via the user.
and it seems most people in the dsm world get the aeromotive 13109 afpr, but i got the 13101 which has larger lines so i can run more fuel later when i expand more.
that's awesome using lights on the dash as a shift light. to bad my instrument cluster looks like a christmas tree with all the lights coming on and off. LOL.
no need for a shift light. you can hear and feel where you need to shift. i have a friend who runs a 6 speed in a 3rd gen camaro that runs 7.80s in the quarter. So don't say you can't shift fast enough.
I def have to keep my eyes on the road when im boosting so i just use my boost meter it will get as high as i want it to got before red line so i just watch the boost guage so i dont hurt the engine sorta i hit 20 psi some times but no problems im sure its not good for my rings but i rarley let it get to that.
in 1g dsms it has an "injector tuner" i just dont see any description can some one fill me in ? thanks.
