who makes 16x8 5x114.3 +40 wheels?
16x8 are not a popular size...anymore. 3000GT and Stealth rims are heavy. Try looking on tirerack under 93-95 RX7 and mid 90s mustangs.
There is always Old Faithful - the 16x8.5 Kosei K1 ?
35-ish offset (forget exactly).
Charles
Found a set of used 16x8.5 kosei K1s with a 37mm offset and 245 Hoosier R3S03's. After rolling the fenders so you think I'll have any trouble with rubbing? Fender roller is rented and should be here this weekend. I think I may powder coat them if the paints crappy...Hmmmm black or white track wheels??
I got some, and I may even think about selling them as the TCE big brake kit needs 17in rims. I have my rear fenders rolled, and use a 10mm spacer on all 4 and they fit.
What are your spring rates? I only have the H&R/Koni yellow set up and I need to tuck ever so slightly... wow! I just looked at your profile and you have Hyperco (850/425) springs. No wonder you don't contact the fenders... Am I crazy for going with this set up on a street/strip/autocross/show car?
I have a used set of 5Zigen Div. 3 wheels, 16x8, 40 offset, 5x114.3 if you are interested. They have no tires, but I'll sell them for pretty cheap. Send me a PM if you are interested.
Jerry
Here I even filled out the form..This along with the suspension as stated above.
TIRE SIZE RECOMMENDATION REQUEST FORM
1. My car is a:
b) 2g DSM
2. My wheel size is:
Diameter: 16
Width: 8.5
Offset: 37mm
3. My current or future suspension height will be lowered
b) One to 1.5 inches
4. If suspension is lowered,
b) Rear camber will be adjusted to within 1° to 1.5° negative.
5. Rear fender flange rolling:
a) My fenders are rolled or will be if necessary.
6. My driving style is:
c) Street and Strip.
d) Street and Autocross.
7. I have searched for and read the FAQ's, Tech Articles, and threads on wheel and tire fitment:
a) Yes, but I just need someone with experience to validate my choices.
    • Sdcryan1
