Whining noise please help
'98 AWD DSM
140
Nov 30, 2003
Sayville, New York
Whats up guys,
I discovered a new sound on my car and I am hoping its not any kind of tranny whine but it probably is. It whines the loudest whenever I let off the gas and when I let off the gas at higher rpms its the worst :cry: I have no idea what this noise is, it also makes the sound whenever I shift into gears. WHen I am on the gas it may do it a little bit but not much at all compared to when I takae my foot off the gas. I just put my clutch in yesterday so its not the throw out bearing, pressure plate, or disc. Anyone have any ideas post away
-Andrew
I just refilled the tranny and transfer case with fluids and it still made the noise will check the rearend. Thanks a lot
How many miles does your car have on it ? Also has it been drove hard ? Could be the frount diff carrier bearing.
I had a similar problem that was solved when I adjusted the clutch pedal height adjustment so that the clutch engaged about a half inch closer to the floor.
Mine would whine as if it was "spooling down" right after engaging the clutch, but only at high rpm.
How long ago did you do the clutch and flywheel? I see you got a fadenza in there. They are know for being loud i think?(correct me if I'm wrong here guy's). I got one and my car makes whining noises to in like 2nd gear coasting to a stop.
