which wideband? quick answer.
hurricanecris24
1,390
12
Jul 14, 2009
NORCAL, California
okay i got a 99 eclipse and gonna be tuning with evoscan which wideband would be better?AEM UEGO WIDE BAND O2 GAUGE?innovative lc1 wideband? i can get both for the same price
I searched everywhere bout the two couldn't find which is better. Okay so I think I'm going for the lc1
thats what i thought. i know someone had mentioned the LC-1 is more versatile, but if someone is using link, wouldn't you have every bit of info you would need with that, no matter what wideband is used?
LOL
The outputs on the AEM are non programmable... And... They are not accurate with what they say is supposed to be outputted.
The logged value on your logger vs. the displayed AFR on the guage will never match.
In essence. Say at 2.5v the white papers for AEM says that the calculation for AFR base from voltage is Voltage x 2 + 10... 2.5v = 15.0AFR. If your at 15.0afr and it's outputting 2.3v to your ECU, your tune is going to be off by a little bit. 2.3v = 14.6afr
This is called a voltage offset. You can program this out with the LC-1 and other programmable units.
+1 for LC-1 :thumb:
LOL
+1 for LC-1 :thumb:
im still stock on my tsi, and i dont plan on making an insane amount of power, so i'll stick with the AEM. im sure if you're making a ton of power, that may have an effect right? a friend of mine is making good power with his 2g, but he has the AEM analog.
i have both the aem uego [external not gauge type] and a couple lc-1's
the lc-1 is just better all around it seems. better sensor life, less headaches. the aem has been a slight nightmare.
the problem with aem's gauge type is the connector is a big piece of shit. cut it off, solder the pins and alot of the flakeyness goes away. {as reported from TheBoz on aem forum}
havent used the ngk setup yet...but its been getting alot of press.
the lc-1 isnt hard to setup, but it is sort of a pain in the ass to mount. I dont know what the hell they were thinking. it has a 2' cord to the controller, and no way to mount the controller! which means you always end up with zip ties and a generally nasty looking install. Much less good ####ing luck mounting it somewhere that is out of the way and protected from the elements.
what makes the LC-1 better? just asking?
wouldnt say its "better" but it seems to be more consistent with its readings. Also the programable outputs are ####ing awesome! esp for those of use hacking stock ecu's.
for example the honda ecu can only read 3.8 volts. so any wideband reading 0-5v is damn near useless as half the scale is missing. lc1 to the rescue. Just rescale the output to read the same afr range over wahtever your available voltage monitoring range is. so 10-20afr from 0-3.8v poof. problem solved.
Lets say you are broke like me, and have an old lc1 but dont want to spend the coin on a gauge? fine. buy a voltmeter off ebay, scale the analog output of the lc1 accordingly and now you can read AFR on any volt meter or in this case a Panel Meter.
lc1 is versatile...i dont consider to be a highly accurate piece of data aquisition gear. yet for the purpose of tuning air fuel it seems to be fine.
my motto is afr tuning is for the longevity of the motor...a leaner motor might make a tad more power, but will make more heat. egt i feel is superior to afr for wot tuning
spark tuning is where all the power is made.
if you tune your car at 12to1 then at 11:1 you probably wont notice a huge change in power. i shoot for 11.5 so given all errors im safely under 12 and happily over 11. part throttle is all done by feel..who cares what the meter reads there :)
