Which valvesprings?
cecil722
69
Oct 5, 2005
houma, Louisiana
I was just wondering if Manley valvesprings would work with HKS camshafts? Or should i buy HKS valvesprings?
yes they would work. valve springs are not matched to cams. i can use manley valve springs for any cams i want and i can do the same for hks valve springs. just pick a valve spring that you KNOW is good for what you want it do. example: i need a valve spring i know that can handle a 9k red line. well i probably dont need top of the line valve springs so i just went with the manley because i know they were good and reliable.
david-
