which tranny
90rslaser
266
Apr 1, 2008
cheyenne, Wyoming
so i've kind of been looking, but too many not right answers keep popping up. which other transmissions will fit in an 1990 awd talon? like will a tranny from a 91 work? or even a 92? if anyone has an extra 90 awd tranny laying around that works and sees this, just message me please. thanks guys.
The 1990 AWD transmission was different from the 1991+ AWD transmission. It had a 22-spline output shaft while the later years had a shaft with 23 splines. The later year transmissions will work so long as you have a matching transfer case with it.
The drive shaft is the same for all 1G AWD cars. The axles used in 1990 AWD cars are the same for all 90-94 5-speed cars, so the axles from your 1990 should work.
  • Wanted 6 bolt NT water pipe
    • chrisman287
